That means the power factor correction is shutting off, which will cause the 375V (PFC output) to drop off to the mains input voltage. This will occur for a number of reasons but prime suspect is the signal which switches the Vcc to the PFC IC.
2SB1188 is a transistor which does this. It is controlled by OPTO PC9502. When MAIN POW is high, the LED in the opto lights, turning on its internal transistor. This pulls the collector voltage low releasing Q9558 to float PON high (through 68k near PFC IC.)
So, you need to check a few things: C-E voltage across PC9502 and the PON signal somehow, may have to solder a wire somewhere e.g. R9520 end near Q9508 (SMD.)
