Author Topic: tv repair help  (Read 20725 times)
Online wraper
  • Country: lv
Re: tv repair help
« Reply #50 on: October 24, 2013, 03:26:38 pm »
I don't know witch one is the collector anyway.
You can figure it out by whith other parts are connected to tat pin according to schematic. For example, if pin of Q9503 is connected to Q9502 and R9521, this is collector. And Usually collector is single pin in the middle of smd transistor. Look at the picture.
Offline snipersquad100Topic starter
    • Electrinics
Re: tv repair help
« Reply #51 on: October 24, 2013, 03:27:59 pm »
which one is the collector lol, 1 2 or 3. I cant find a datasheet on it as It got no number.
    • Electrinics
Re: tv repair help
« Reply #52 on: October 24, 2013, 03:29:12 pm »
oh ok ingnor that 123 pic
    • Electrinics
Re: tv repair help
« Reply #53 on: October 24, 2013, 04:14:47 pm »
ok, C of Q9503 = 0.01v
     C of Q9502 = 4.5v
     E of Q9507 = 17.2
and pin 8 of Ic9502 = 17v
Offline tom66
Re: tv repair help
« Reply #54 on: October 24, 2013, 04:25:01 pm »
Whereabouts are you in the UK? If you're near me, I would actually pay money for this faulty set as described. If you give up on it...
Your ground for primary side where do you have it?
    • Electrinics
Re: tv repair help
« Reply #55 on: October 24, 2013, 04:30:25 pm »
im in Swansea. I used the -side on bridge rectifier as it says gnd1 on the schematic.
Online wraper
  • Country: lv
Re: tv repair help
« Reply #56 on: October 24, 2013, 04:33:33 pm »
In that section everything seems OK. As I understand at the same time there is only 330V on 375V rail. So I need some more checks. Please measure voltage between GND1 and pin 1 of IC9502. Then measure voltage across C9503 and across C9501. If voltage across capacitors is almost the same (what means PFC is really dead), switch TV off and then measure resistance of K9502 fuse, R9529, R9530, R9502. Be sure That C9501 discharges before measuring those resistors and fuse.
Offline tom66
Re: tv repair help
« Reply #57 on: October 24, 2013, 04:33:48 pm »
Lol, OK. Leeds. I used to live down near Reading so I would pick it up otherwise. But anyway, even if you decide to get rid of it, it will be gone the next day if listed on gumtree for £30 as faulty...
The HIGH ignal at collector of Q9502 is good, this will turn on Q9508 which should turn on Q9507.
So what do you get at C of Q9507?
    • Electrinics
Re: tv repair help
« Reply #58 on: October 24, 2013, 05:49:22 pm »
Gnd 1 to pin1 of Ic9502 = 2.5v
C of Q9507 = 17v
V across C9503 = 330v
V across C9501 = 332v
Resistance
K9502 = 0.09 ohms
R9529 = 100 ohms
R9530 = 22.09 ohms
R9502 = 0.2 ohms
Offline tom66
Re: tv repair help
« Reply #59 on: October 24, 2013, 05:52:01 pm »
You should have 375V if that is as it is. If not, IC9502 may be defective, you replaced it? If so check C9502 for int short, try flexing it.
Online wraper
  • Country: lv
Re: tv repair help
« Reply #60 on: October 24, 2013, 06:10:05 pm »
Strange that there is 2,5V on pin 1 as there should be 2,5 at 375V output as it is feedback pin and only 2,2V on 330V. So Either there is something wrong with sense voltage divider or ic9502 is dead. Check R9514 and R9515. Their resistance in paralel should be 16,6 kOhm, however surrounding circuit can influence it. Check also R9512, R9513, R9516. I think we are very close to find the fault.
« Last Edit: October 24, 2013, 06:13:17 pm by wraper »
    • Electrinics
Re: tv repair help
« Reply #61 on: October 24, 2013, 06:56:30 pm »
R9514 = 16.2 ohms
R9515 = 16.2 ohms
R9512 = 828k ohms
R9513 = 780k Ohms
R9516 = 780k Ohms
the last 3 readings were up and down, might be cos they in circuit.
Offline tom66
Re: tv repair help
« Reply #62 on: October 24, 2013, 06:57:49 pm »
Do you mean 16.2 kohm or 16.2 ohm really?
    • Electrinics
Re: tv repair help
« Reply #63 on: October 24, 2013, 07:02:25 pm »
16.2k sorry on both
    • Electrinics
Re: tv repair help
« Reply #64 on: October 24, 2013, 07:06:34 pm »
yea I changed that ic today same fault. yesterday I paralleled up that big cap with a 470uF 450v cap, no change. its tight to the pcb and solder looks ok, I did resolder it yesterday too.
    • Electrinics
Re: tv repair help
« Reply #65 on: October 24, 2013, 07:14:31 pm »
c9501 I ment, I check c9502 now
Online wraper
  • Country: lv
Re: tv repair help
« Reply #66 on: October 24, 2013, 07:25:52 pm »
R9512 = 828k ohms
R9513 = 780k Ohms
R9516 = 780k Ohms
That's strange, because they are in series and all 820K so should read the same even in circuit. Try to desolder R9512 and check resistance. Then check 2 remaining resistors as they are no longer connected to the circuit and must read real value.  Look also what is written on them, they should be the same 820k but who knows. And measure R9514 again before soldering R9512 back.
    • Electrinics
Re: tv repair help
« Reply #67 on: October 24, 2013, 07:51:12 pm »
ok,
R9512 = 822k numbered 824
R9513  = 787k   nr    824
R9516  = 778k   nr    824
that's not right surely ?
Online wraper
  • Country: lv
Re: tv repair help
« Reply #68 on: October 24, 2013, 07:59:04 pm »
Yeah, 2 resistors are way off, and strangely to lower side what is not usual. Thats seems to be the fault. Replace all 3 to new ones as there is potential that 3rd resistor will go bad later. Better use 1% resistors as a replacement or if you use 5% ones check them before soldering that total value of them in series would be not worse than 2460 kOhm +-1%
    • Electrinics
Re: tv repair help
« Reply #69 on: October 24, 2013, 08:03:13 pm »
im going to have to order them, unless I bodge it up with throu hole lol
Online wraper
  • Country: lv
Re: tv repair help
« Reply #70 on: October 24, 2013, 08:17:33 pm »
Well, you can bodge temporarily to see how it works.
    • Electrinics
Re: tv repair help
« Reply #71 on: October 24, 2013, 09:03:16 pm »
The 375v rail has gone from 345 to 383volts, ive just turned it on, fingers crossed, touch wood lol.
    • Electrinics
Re: tv repair help
« Reply #72 on: October 24, 2013, 09:18:53 pm »
It's Still on, I think it's safe to say its fixed.
Thank you guys.
Online wraper
  • Country: lv
Re: tv repair help
« Reply #73 on: October 24, 2013, 09:44:34 pm »
Happy for your succesfull repair  :-DMM
Offline tom66
Re: tv repair help
« Reply #74 on: October 24, 2013, 09:55:47 pm »
Nice, interesting to see the failure of the resistors to decrease in value rather than the typical increase due to excessive heat.
