Interesting, maybe I should take that route. Do you just spray each part and see what happens until you get it?
I took a bit more of "scientific" approach because the PSU board in this telly is *big*. I used a binary search. Heat the whole board with a hair dryer until it is way past the point where it fails, then hit half the board with freezer. That will tell you which half of the board the fault lies on.
Repeat, doing a half of each area at a time until you narrow it down to a small area. Get it nice and cold, and then just heat up each component until you get the one that causes it to fail. Mine was on the live side of the set, so I used a gas iron and just touched one pin on each SMD component until I found the one most likely to make it fault. Repeated that a few times just to be sure, and replaced the part. It was a weekend and I didn't have any SMD MLCC's. Measured the voltage in circuit to make sure I could use a standard part and just replaced it with a small leaded component.
It's a lot easier with through hole components, but same principle with SMD's.
I did a similar thing to repair the PSU on my Apple Thunderbolt Display. One of the SMD MLCC's had gone short and was causing the PSU to go into immediate protect mode. I suspected it was an MLCC that was faulty as all the electros are solid polymer, so I just hit each one with the CRO until I found a rail that was shorted (no pulses as the PSU tried to start up). There were only 3 on that rail, so I just removed/replaced one at a time until it sprung to life. SMD soldering tweezers made life easy there, although I have a couple of forked Hakko tips also. They are just harder to use as you need a bit of digital gymnastics to be able to grip the component whereas the SMD tweezers desolder and remove in one motion.
Odds are it's probably an Electro on your telly. Mine were all top quality 105C Rubycon parts, but it didn't stop me hitting them all with freezer first up just in case. I did a PSU in a Cisco 3550 switch that had a thermally sensitive Electro in a similar fashion. Through hole Electros are easy though because you can just rest the gas iron on the aluminium cap to heat them up selectively.
