Bidirectional is good from a buyer's side, you only need a single part for all applications, and putting it it the wrong way round does not cause any issues. If you need unidirectional you just use a regular diode in parallel as well. Yes you will need to build a tower to use the unidirectional ones to replace a bidirectional one though.
