Hi guys - This will manly be a repair/restoration log. I bought two HP6253A powersupplies - two times 20V/3A output (but it will go higher, manual just goes "we don't guarantee it's noise performance"). One of the units I received was broken (I was aware of this, and it's the reason I bought it - an fully analog, old school PSU seemed like a great first big-boy repair project. In fact, the thing doesn't even have any IC's, at best a matched diff pair!
The powersupplies are basically two fully isolated devices - even have their own fuses and transformers. The only thing they share is the power cord and the big clunking switch on the front.
One of the two supplies (the one with a broken channel) seems to have almost no use. I suspect either it was damaged in the first few hours of using it, got shelved and never got repaired, or it was a backup unit in a production test setup and it never even made it out of the box. It's clean inside, which seems to confirm this. The datecodes inside of the device are all 1989, suggesting it was one of the later models. It has the nice HP terminals, only problem I have is that it's (in my opinion) got non-sensible colors: Red for both positive and negative, black for earth. This is one of the things I'm thinking of changing. I'm already using this supply to power some LED's I'm running as a desk light. (the broken channel's fuse is removed, so it doesn't turn on)
The other supply is a bit older and has clearly seen use. It's got quite a bit more dust going on inside. Both channels work. This supply is also outfitted with the crowbar, which is something I'll have to play around with.
A few things I want to look at doing:
- Clean up the supplies. Check if there are components that need replacing (capacitors etc.). Give some of the components a clean (the powerresistors in the back have a good amount of dust stuck to them that smells when you push the supply. The resistors are rated to 350 degrees C so they will burn whatever biological residue is on there)
- Look at changing the front terminals. On the old supply, the terminals are not the nice HP type. I am thinking of replacing them with the HP style ones. The new supply also has red for both positive and negative terminals. I'm thinking of changing that to be red for positive, black for negative and green for earth.
- Add power sockets. Currently they have (or at least one of them does, the other I already removed it) fixed power chords. Since they are imported from the states I had to replace the plug on the one I'm using. I would however like to get IEC14 style mains sockets on there. Requires a lot of file work so I will see how it goes.
- Output on/current set switches. Currently, the supply will turn on it's output as soon as the devices is powerd on. I would like to look at changing this, so it has an output enable and I can set to voltage without the output being turned on. The supply is quite roomy so I should be able to fit in a mosfet switch (or something similar) to do this. Similarly, a switch to short out the output for setting the current limit would be interesting.
- Bring sense terminals to the front. The sense terminals are at the back currently. I think it would be usefull to see if I can bring them to the front as well.
- Consider changing the fine/coarse adjustment to a 10turn pot. Currently it's using a fine/coarse style adjustment for voltage and current. I'm going to look at exchanging them for 10 turn pots. However, as 10 turn pots cost quite a lot, I don't think I will (8 ten turn potentiometers are not going to be cheap)
- Lighting for the meters. I think it would be usefull if I could get some kind of lighting in the meters so I can easily read them even in poor lighting conditions. I'll have to see tho, I don't want to risk damaging one of the meters.
Now ofcourse, some important pictures!
The "old" supply. It's missing a frame around one of the meters but it still works fine. I've already taken the cover off because I decided to start this "log" only after starting to tinker. You can clearly see it's been used, it has a big scratch on the front, and you can tell by the terminals and the potentiometers that they have been handled. It's come out of a rack, as evidenced by the marks of the mounting hardware.
One side of the old supply's internals. I removed the power resistors already as I started looking at how to place a IEC socket.
Transformer seems to have a datecode of 71, latest datecode I could find is 73.
The newer supply. Notice it is very clean from the front, no scratches or marks of wear. It has rubber feet as well, something the other supply does not have. In this picture it's powering the LED's I use to light my desk while studying (exam period, I'm doing this in my breaks, twice a day I take half an hour to work on these things).
The insides of the new supply. It really is very clean!
And the damaged section of this supply. The two burned components are CR19 and R35. A quick probe yesterday seemed to indicate that CR18 is also measuring a short. I'll have to take a look at this. Current suspicion is that CR18 being a short allowed current to be injected into CR19 and R22 from Q7, bruning them up. I've not spent much time on it though, this is something I'm waiting to do after my exams.
For those who want a schematic, the manual can be found on Keysight's website:
http://www.keysight.com/en/pd-1000001530%3Aepsg%3Apro-pn-6253A/power-supply?cc=US&lc=engFeel free to give tips, ask questions, etc...
