Today I had to uninstall some large evaporator fans from the chilling compartments of a fishing boat. The fans were run by three phase induction motors. To my surprise, some of the motors were strangely wired. There were two connections of four-core cables. Each cable had three phases and a ground wire.
First, I assumed that the two connections were used for star delta configuration. However, when I saw the nameplate of one of the motors, I got a satisfying clue. The internal configuration of these motors allowed them to run on two different numbers of poles in order to provide speed variation. With four poles, it spins faster and with eight poles, it spins slower. That's my best attempt in interpreting the nameplate.
Can you have look at the name plate and confirm if my interpretation is correct?
