Author Topic: What component does" TR" used for on power board  (Read 495 times)
Offline abdolahTopic starter
  • Country: eg
« on: April 14, 2024, 05:28:05 pm »
Hi guys, hope your day is going well
I was measuring some components on this power supply that was shutting off after a while and the doesn't power on anymore, the component is in the photo below, it looks like a bead firrite, but the text simple is not for that its "TR" , I don't know what is for but the component is measuring high impedance
If any one know please share it
Thanks
Offline helius
Re: What component does" TR" used for on power board
« Reply #1 on: April 14, 2024, 07:00:55 pm »
According to standard nomenclature that is a thermistor.
Thermistors (or temperature-dependent resistors) can either increase or decrease their resistance with temperature. These are called PTC and NTC respectively, for positive/negative temperature coefficient. The first type is also sometimes called a posistor.
If you test the resistance of the component at room temperature, and then after either heating with heat gun or using cold spray, you should see whether it is PTC or NTC.
The following users thanked this post: abdolah
  • Country: eg
« Reply #2 on: April 15, 2024, 12:54:03 am »
Thanks for the reply I really appreciate it
