Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
This topic
This board
Entire forum
Google
Bing
Home
Help
Search
About us
Links
Login
Register
Electronics
Repair
UC10A counter repair
« previous
next »
Print
Search
Pages: [
1
Go Down
Author
Topic: UC10A counter repair (Read 1741 times)
texane
Regular Contributor
on:
September 27, 2015, 10:49:37 am »
I recently retrieved a malfunctioning uc10a frequency counter. I
opened it and tracked the issue to the icm7226a chipset. This chipset
implements the core frequency counting and display. I am using the
following datasheet:
http://www.intersil.com/content/dam/Intersil/documents/icm7/icm7226a-b.pdf
The IC is powered correctly, but I noticed that there is no signal at
pin 38 (buf osc out). Thus, I suspect the main oscillator stage to be
defective.
When looking at the datasheet p.13, I see that the Pierce oscillator
caps (39pF) are connected to VDD, not GND. On the actual device, they
are connected to GND. Do you think there is a mistake in the datasheet ?
Thanks for your help !
Logged
SeanB
Super Contributor
Country:
Re: UC10A counter repair
Reply #1 on:
September 27, 2015, 12:38:46 pm »
Makes no real difference, it just is the load capacitors are just required across the crystal, so where the midpoint is connected makes no difference from the loading point. As a quick test of the crystal unsolder it and solder it back in with the leads swapped. This often does work with old crystals to help them start up and work again. If it does work then you can either leave it in, and it will work for a few years again, or get a replacement one and solder it in.
Logged
texane
Regular Contributor
Reply #2 on:
September 27, 2015, 04:11:06 pm »
Thanks for the answer and tip. I tried to rewire the quartz but it did not help. Also, I tried with another new one, changed caps, built an external oscillator ... nothing worked. I guess the chipset is dead :/
Cheers,
Logged
Print
Search
Pages: [
1
Go Up
« previous
next »
Electronics
Repair
Thanking...
EEVblog Main Site
EEVblog on Youtube
EEVblog on Twitter
EEVblog on Facebook
EEVblog on Odysee
