So after further testing, it turns out that one of two 47 K
resistors was burnt and the other out of spec (55 k
Didn't have any 47 k
resistors on hand so decided to replace both with 50 k
resistors just to see if it solves the issue and guess what, problem solved.
Now the machine works again however after taking out my thermal imager, it was apparent why these resistors went bad after some time: After a couple of minutes of on time, the two 2.2
resistors adjacent to them were reaching into the 140 C
Not sure why that's the case and also the power seemed to drop drastically as the power draw from the wall went down from 26W to around 17W in the same time span.
My guess is since these resistors are getting so hot, their resistance values is increasing causing a large voltage drop which in turn drops the output power down.
What is strange however is that I never noticed this kind of behavior prior to the unit failing. Should I just replace these with 5W models to reduce the heat output and power sag or is there an underlying problem that I am missing here?
