Author Topic: Unbrick Tektronix RSA3308 RSA3303 WCA280  (Read 12062 times)
Offline chinhcheng
  • Country: vn
Re: Unbrick Tektronix RSA3308 RSA3303 WCA280
« Reply #50 on: November 25, 2025, 03:35:13 am »
Hi squadchannel
Thank you very much for sending the files. I have successfully extracted them and the instrument now recognizes the hard drive and the software is running.
However, the unit is showing the error “Error: Self gain cal (0.00 dB)”. I tried enabling the CAL signal in the Input menu — the 25 MHz signal appears correctly, but the 100 MHz signal does not show up.
I also tested external signals: frequencies below 40 MHz are OK, but from 40 MHz to 50 MHz the instrument reports A/D OVERFLOW and the signal behavior is very abnormal. Above 50 MHz up to 8 GHz, the unit does not detect any signal at all.
It seems that I still need to resolve some hardware issues before the analyzer can operate normally again.
Anyway, thank you very much for your help with the software side.
Offline nguyenj100
« Reply #51 on: August 30, 2026, 03:05:49 am »
Hello, I recently acquired a RSA3408A with a corrupt hard drive and was hoping to find a drive image. There was a link posted earlier, but it currently does not work. If someone can help repost that link. it would be very appreciated!
Thanks in advance.
John
Offline tv84
  • Country: pt
« Reply #52 on: September 15, 2026, 06:02:22 pm »
Where exactly does the RSA3408A get its UniqueID?
MAC address.
Offline nguyenj100
« Reply #53 on: September 21, 2026, 06:41:09 pm »
Hi chinhcheng,
We're you able to figure out your “Error: Self gain cal (0.00 dB)”? I have run into a similar issue with my unit as well. Please share with me if you have had any luck with this.
thanks,
John
