Hi, i've the news, the final news!!
I found that one of DC/DC converters doesn't work! and for that reason the application in my case doesn't start.
It was hard to find beacuse there are 12 leds for the voltage check,in my case two of that are a little deep, and with a dmm i found that the 6.8V used for the RF circuits are at 3.3V.
it is very strange, tektronix (japan!)use two DC/DC UWR-3.3/4250-d24A to create the 6.8V from the 24V, each 3.3V. This dc/dc are very expencive for a 15W, the very problem was fix it. With a little luck they are incaspuled with silicon rubber and find the broken mos was simple (FDS6680)..
The converter works with 2 mos (sync bridge) and works ony if the mos are the same.
To summirize, the application run , know my work is to restore the calibration files.
For unbrick, the only file that need the system is the option.cal with the hardware key.
Now i change my RSA3308A to RSA3408A!! with more decoding option
Again thank for your support. Have a nice test
