My Bosch washing machine's motor control board has failed. After removing the board I found that there seems to be purposefully undersized traces being used as a brute force "fuse". In the attached picture I show the failed traces. There are two of them on either side of a NTC. Do you think that I would be risking fire if I repaired the trace with either conductive paint or a piece of wire wrap wire?
Thoughts?
