Displaying "detect test mode" for a short time when switching function is normal, I think DSO/CPU board waits for serial data from FS9721 to know what mode that has been set to.
I don't know if lack of serial data in scope mode would freeze the display all together or only prevent voltage/current readings, it may be worth having a look if serial output is reaching the CPU.
If your trouble showed up during the rain season, I'd certainly have a look at the function selector switch contacts.
You may also be inspired by the troubles I had with mine:
https://www.eevblog.com/forum/repair/uni-t-ut81b-scopemeter/
The fix is easy when you know it but does involve desoldering the interconnect for cleaning.
Calibration mode is only for waveform display, all the DMM adjustment is done with trimpots.
Ha Ha, talk about timing. I had just finished drawing the schematics rough draught last night and had noticed the ONLY way the two boards could tell which position the mode switch was in was the serial output from the primary DMM chip.
And of course i wake up to your response, really gave me a chuckle.
I did check serial output from the DMM chip when it first failed and no output, oddly though it does have some output to the "DMM LCD OUTPUT" showing some function but still no serial data making me think the FS9721 failed as i am probing at the chip output and have confirmed TX_EN is grounded and MEA1-4 are switching at the chip.
My plan today was to inject some serial data into the line to confirm last nights theory which today you confirmed.
hopefully i can purchase one of FS9721 chips online without headaches
darkspr1te
