Author Topic: (FIXED new battery woW) UNI-T UT204A Clamp Meter problem need fix  (Read 1328 times)
Offline MkdsimeTopic starter
  • Country: mk
Hi i have UT204A clamp meter it fell softly and now when i press the select or rel or hold button it beeps sometimes display goes crazy and shuts down. I have cleaned the connections on the pcb, measured the transistors with diode test directly on the board all 'Y1' SMD transistors have short between 2 pins. What could be the problem if someone knows please help somehow thanks and take care.
here is a video of it:
https://youtu.be/luY6mjhX_-Q
this is a image when i press the select button it beeps screen goes all in and goes to the 1st measuring unit selected with the wheel
« Last Edit: February 04, 2019, 10:44:49 am by Mkdsime »
  • Country: mk
Re: UNI-T UT204A Clamp Meter problem need fix (with video)
« Reply #1 on: February 04, 2019, 10:44:13 am »
so i bought brand new battery and it worked wow
the battery inside was 8.9V I've tested it with 9.2V both are cheap batteries and now change it with branded one 9.7V fully charge
thanks to everyone seeing this post and to mr. "jutt engineer" on youtube
