Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
This topic
This board
Entire forum
Google
Bing
Home
Help
Search
About us
Links
Login
Register
Electronics
Repair
Looking for a micro usb smd pcb tower connector for repair of TomTom Start 60
« previous
next »
Print
Search
Pages: [
1
Go Down
Author
Topic: Looking for a micro usb smd pcb tower connector for repair of TomTom Start 60 (Read 2460 times)
obiwanjacobi
Frequent Contributor
Country:
What's this yippee-yayoh pin you talk about!?
on:
July 29, 2016, 12:41:21 pm »
My TomTom Start 60 has intermittent USB connection resulting in random phantom screen touches and trouble with charging. Driving on bumpy roads causes the unit to become unusable.
The USB connector seated in the connector is very wobbly and I think that is the problem. I have opened my TomTom up and soldered the case/ground leads but that did not do the trick - I think the connector is broken internally.
A somewhat unusual USB connector is used in the TomTom Start 60. I think they call it a tower USB connector for it's receptacle is lift of from the PCB some distance.
I think its very similar to this one:
http://www.ebay.co.uk/itm/tomtom-Parts-NEW-Micro-USB-TOWER-socket-Weison-G3515-39-x-1-Piece-/232022627785
I was just hoping I could get one for less than 10 pounds per piece...
Any ideas?
Thanx.
Logged
Arduino Template Library
Zalt Z80 Computer
Wrong code should not compile!
stj
Super Contributor
Country:
Re: Looking for a micro usb smd pcb tower connector for repair of TomTom Start 60
Reply #1 on:
July 30, 2016, 01:22:28 am »
did you try another cable first?
Logged
obiwanjacobi
Country:
Reply #2 on:
July 30, 2016, 06:14:18 am »
Quote from: stj on July 30, 2016, 01:22:28 am
No, because it has a specific connector and just wiggling the cable in the TomTom socket also reproduces the problem...
Logged
Zalt Z80 Computer
stj
Super Contributor
Country:
Reply #3 on:
July 30, 2016, 01:31:50 pm »
maybe the bad contact is on the cable end.
what's so "custom" about it?
Logged
obiwanjacobi
Country:
Reply #4 on:
July 30, 2016, 01:50:36 pm »
(in the meantime) I did try another cable and it does fit -did not expect that- but the problem is still there. Although the original cable might also have problems so I will be replacing that, but a new cable is does not fix it.
Thanx.
Logged
Zalt Z80 Computer
jkf1000
Regular Contributor
Country:
Reply #5 on:
July 30, 2016, 09:56:57 pm »
The Ebay link you supplied quotes £5.99 and £3.49 shipping to the Netherlands. By my maths that still works out at under the £10 you mentioned.. Karl
Logged
Print
Search
Pages: [
1
Go Up
« previous
next »
Electronics
Repair
Thanking...
EEVblog Main Site
EEVblog on Youtube
EEVblog on Twitter
EEVblog on Facebook
EEVblog on Odysee
