I was messing around with a dumpster score (barcode reader) and powering it up with my lap power source, a cheap Uni-T UTP3313TFL.
All was working, but then the wires connecting to the barcode reader were intermittent (too thin diameter to get better contact) and after a while, suddenly there was no power up.
I looked and noticed that the power source went to C.C. mode with 0.0V and 0.0A (occasionally changing to 0.1V or 0.1A).
Reading the manual, this is the mode, where you short + and - to set the maximum current.
I turned the power source off and measured GND against + and there is some resistance. It seems to me that some diode must have broken?
Any thoughts on how to repair this?
The device is under warranty and it should NOT break from what I was doing. But then, I should have used a better contact instad of an intermittent one. Also, I don't feel like going through all the support issues, which probably end up costing more than a new power source.
The problem with the repair is:
a) I have no knowledge on how these things work.
b) It is highly compact device with difficult access, unleass I tear it completely apart, but it does have a lot of glue around.
Any ideas are welcome.
Regards,
Vitor
