Author Topic: Unknown (to me) CFL inverter part  (Read 1073 times)
Offline mondrotaTopic starter
« on: July 05, 2019, 07:35:39 pm »
Hi all
Sorry if this sounds silly but would anyone be able to tell me what this part is (attached)?
It's from a cfl driver board, quite clearly toasted and caused the backlight to flicker.
I'd like to get it going again but I have no idea what this part is. I think it was marked as a capacitor on the pcb. I tried putting a random one in but no joy :)
Thanks in advance!
Offline Chriss
Re: Unknown (to me) CFL inverter part
« Reply #1 on: July 05, 2019, 07:59:59 pm »
I assume it is a 0.01uF non polarized cap.
For sure it is a cap but I can't see clearly the marking for the value.
Sent from my SM-J500F using Tapatalk
Offline Chriss
« Reply #3 on: July 06, 2019, 07:04:52 am »
Can you pls post a picture about the circuit where your cap is?
« Reply #4 on: July 06, 2019, 09:52:48 am »
Here it is!
Offline shakalnokturn
« Reply #5 on: July 08, 2019, 12:21:53 am »
I'd bet on a Kemet 100nF 100V MKT for the original part.
Then you'll want to be checking the small green fuse, transistors (quick no-shorts) and thermal fuse.
