Author Topic: Unknown component  (Read 1613 times)
Offline davidclancybellTopic starter
Unknown component
« on: July 26, 2021, 11:54:03 pm »
I am attempting to repair a Asus Z97 MB. I had a puff of blue smoke from a component. Does anyone know the component I need to replace, pic attached
Offline james_s
Re: Unknown component
« Reply #1 on: July 26, 2021, 11:58:33 pm »
That's a resistor network, going by the number on it I'd say it's a 0 ohm network, ie a set of jumpers. What caused it to burn up? Jumpers don't just fail, something resulted in an excessively high current at which point that device acted as a fuse.
« Reply #2 on: July 27, 2021, 12:35:40 am »
thanks for that. Not sure why it smoked, the pc has been in storage for a while and there seemed to be some corrosion on one of the pins. I am ok at re-soldering so what am I ordering on Ali-express to replace it. Do you think this would prevent the machine posting? Thanks
« Reply #3 on: July 27, 2021, 03:09:53 am »
Are you sure the puff of smoke didn't come from the package to its right? That's most likely a transient voltage suppressor (TVS diode array) and that's a device I'd expect to smoke itself if the wrong thing went into the USB port that it's connected to. A zero ohm resistor array is probably going to be a relatively tough customer.
« Reply #4 on: July 27, 2021, 04:00:17 am »
Think I found it but no idea what it is or why it blew
Offline fzabkar
« Reply #5 on: July 27, 2021, 04:14:45 am »
That looks like a DC-DC converter, assuming it drives the nearby inductor.
« Reply #6 on: July 27, 2021, 04:18:33 am »
OK thanks for that. Would you have any idea on the package number, going off what's left showing
Offline fzabkar
« Reply #7 on: July 27, 2021, 04:31:19 am »
It's best to view the part in the context of its surroundings, but if I were to hazard a guess, I'd say that its manufacturer was ON Semiconductor, or maybe Richtek.
Can you show us a more complete picture of the board?
BTW, there is a possibility that Vin has punched through to Vout, in which case their may be additional damage downstream. Can you measure the resistance between the inductor and ground?
« Last Edit: July 27, 2021, 04:34:12 am by fzabkar »
« Reply #8 on: July 27, 2021, 04:46:19 am »
Sure can. Thanks
« Reply #9 on: July 27, 2021, 04:52:51 am »
chip ringed
Offline Rasz
    • My random blog.
« Reply #10 on: July 27, 2021, 06:34:52 am »
Offline perieanuo
« Reply #11 on: July 27, 2021, 07:19:18 am »
maybe https://www.richtek.com/assets/product_file/RT8065/DS8065-08.pdf i'll have to dig more, i don't have exactly your mobo schematics
finally i opened one board view ASUS Z97-A REV 1.03B - Boardview (.FZ), it's (almost for sure) RT8065ZQW
« Last Edit: July 27, 2021, 08:23:06 am by perieanuo »
The following users thanked this post: fzabkar
« Reply #12 on: July 27, 2021, 09:12:03 pm »
thanks guys. Trying to open the .fz file with Fritzing but get a parsing error at line 1 |O
Offline james_s
« Reply #13 on: July 27, 2021, 09:14:51 pm »
Why are you trying to open it with Fritzing? It says it's for Boardview which is a different program.
Fritzing is garbage IMO, I have no idea how it got as popular as it did, the sooner it dies the better.
« Reply #14 on: July 27, 2021, 09:30:06 pm »
OK got it using BoardViewer  :-+
