Author Topic: unknown component  (Read 603 times)
Offline mooseTopic starter
unknown component
« on: January 27, 2023, 11:50:50 am »
Hi
Can anyone please help me identify the component or even the type of component.
It has 6 pins.
pins 1/2/5/6 are shorted together.
This component is in a Black & Decker 18V battery charger.
There are 3 of these components on the PCB.
thanks in advance
« Last Edit: January 27, 2023, 11:53:04 am by moose »
Offline shakalnokturn
Re: unknown component
« Reply #1 on: January 27, 2023, 01:01:51 pm »
A bit of a guess, considering resistor and 4 pins shorted together I'd say probably MOS transistor.
On photo 4 grouped pins as Drain, top-left Source, top-right Gate.
Knowing encapsulation type would help in finding exact reference.
The following users thanked this post: fzabkar
« Reply #2 on: January 27, 2023, 01:18:48 pm »
my apologies, but what do you mean by "knowing encapsulation type"??
Offline gamalot
  • Correct my English
    • Youtube
« Reply #3 on: January 27, 2023, 01:22:46 pm »
"knowing package type" I guess.
For me, a picture that can see the components around the unknown chip would be more helpful.
« Last Edit: January 27, 2023, 01:24:39 pm by gamalot »
Offline PA0PBZ
« Reply #4 on: January 27, 2023, 01:29:09 pm »
« Reply #5 on: January 27, 2023, 01:43:03 pm »
in that case it is SOT23-6.....(i just measured it 3.0 x 2.75)
the resistor (300K) seems to be some type of 'bypass' to pins 3/4.
But your link DOES make a lot of sense as the Drains connect to another 814 at the Source pin.
« Last Edit: January 27, 2023, 01:49:30 pm by moose »
« Reply #6 on: January 27, 2023, 02:21:26 pm »
and following on from that suggestion this device seems to fit completely!!
https://4donline.ihs.com/images/VipMasterIC/IC/TWSC/TWSC-S-A0003171389/TWSC-S-A0003171389-1.pdf?hkey=6D3A4C79FDBF58556ACFDE234799DDF0
TSM3481...30V P-Channel MOSFET by taiwan semiconductor...they show the marking as "81YML" where Y = year, M = month, L = lot
thank you everyone!!!
