Electronics => Repair => Topic started by: NiaDebesis on March 19, 2023, 09:25:36 am
I am repairing an old switching PSU and I found an unknown component, can you help me identifing it?
Any help will be appreciated.
other photos
It's some custom module.
So if its broken I am screwd
Well, likely it can be taken apart and repaired but it will be very troublesome as it's most likely potted.
Possibly a resistor network??
no chance.
Looks like a hybrid IC, how old is the device?
The good news is that it looks like a casual switching power supply, judging by all the surrounding transformers and the optocouplers. Maybe the whole thing can be replaced with a generic SMPS with the same output voltage. Try to look at the silkscreen, or try to get a service manual in order to find the outputted voltages and their max currents.
What type of equipment is it? Manufacturer and model number?
Maybe a single in-line relay, or resistor networks.
Well, I looked again and I noticed that the OP said it's a SMPS, but couldn't find any IC on the board, not even a BJT or MOSFET, so it's most likely a thick film IC module.
IMHO it's just a potted circuit on regular FR-4. Maybe a hybrid on ceramic substrate, but I don't think so. Those usually have a hard coating and no enclosure.
(https://upload.wikimedia.org/wikipedia/commons/b/b0/Hybridcircuit.jpg)
Imho really demands reverse engineer to have its vicinity schematic
is in primary or secondary part ?
