This may be a little out of order, as I am hoping someone can identify a "strange" component in a toaster! It's an expensive toaster, made by Siemens and designed by Porsche. The circuit board controller is plain enough, but contains one component that seems to do nothing. I've attached a couple of photos of the item; they are poor quality and I doubt they shed much light. It's a black plastic cube about 6 - 7mm on each side. There are four angled pins to connect with the pcb. Strangely, two pins are connected to ground and the other two are connected together and to an I/O pin on the Holtek microcontroller. There are no marks on it, unlike the other parts, and it's not made in China. The only static test I've made is to do a diode check across the two connected pins; one direction gives ~0,6V and reverse gives ~2.6V. As far as I can see, monitoring the uC pin shows no activity, i.e. 0V when powered. As it's positioned on the edge of the pcb I thought maybe a reed switch, but no magnet in sight, and it doesn't respond to a magnet, like a Hall sensor. So I'm baffled, or perhaps Porsche have some secret toaster technology?
