Author Topic: Unknown IC  (Read 1452 times)
Offline brouillonTopic starter
  • Country: dz
Unknown IC
« on: November 25, 2024, 09:18:52 am »
Hello there,
While repairing an electronic board I found this circuit without reference or hidden on the other side, I cannot identify it, does anyone know what it is and its reference?
Thank you.
Offline Chalcogenide
Re: Unknown IC
« Reply #1 on: November 25, 2024, 09:57:30 am »
That looks like some kind of high-ish device (power audio amplifier maybe?) that has a "flipped" package that exposes a thermal pad for heat dissipation.
The markings are on the bottom, but you need to desolder the chip to read them.
  • Country: dz
Re: Unknown IC
« Reply #2 on: November 25, 2024, 10:19:59 am »
Thank you for the response but it's an industrial ic, i think it drives a 3 phase motor!!?
Offline coromonadalix
Re: Unknown IC
« Reply #3 on: November 25, 2024, 11:08:33 am »
could be anything powerful  like igbt,  scr triacs   etc ... even a mix of many since there is a lot of pins
Offline fzabkar
Re: Unknown IC
« Reply #4 on: November 25, 2024, 05:14:26 pm »
The following users thanked this post: coromonadalix, JoeyG
  • Country: dz
Re: Unknown IC
« Reply #5 on: November 26, 2024, 08:13:55 am »
Thank you.
Offline JoeyG
Re: Unknown IC
« Reply #6 on: November 26, 2024, 11:23:36 am »
+1    3 phase power module  which has 3 phase  H bridge  6 IGBTs in one package and integrage drivers etc.
Offline DavidAlfa
Re: Unknown IC
« Reply #7 on: November 26, 2024, 01:13:26 pm »
Did you desolder it and looked under? There wasn't any marking?
Seems the usual 3-phase driver seen in many appliances, specially washing machines.
There're lots of drivers using that package (27-PowerDIP).
https://www.digikey.com/en/products/filter/power-driver-modules/296?s=N4IgjCBcpgbFoDGUAuAnArgUwDQgPZQDa4sAzACwCsFIAungA4pQgDK6AlgHYDmIAXwF540EJwAmrALRgADCCYtIIRSBQBPRllaCBQA
« Last Edit: November 26, 2024, 01:26:17 pm by DavidAlfa »
  • Country: dz
Re: Unknown IC
« Reply #8 on: November 26, 2024, 02:11:33 pm »
it's ok guys i found it. it's FNB35060T an intelligent power module. Thanks to all for your responses.
Offline u666sa
  • Miami, FL
    • Codernov Electronics Repair
Re: Unknown IC
« Reply #9 on: November 26, 2024, 04:06:43 pm »
Curious. These can be bought?
Re: Unknown IC
« Reply #10 on: November 28, 2024, 08:47:18 pm »
yes on some very good sites, lead time seems enormous in some, 37 to 44 weeks,  some will have them in 2025 1st quarter  ...
it is not EOL   around 25 to 35$ usd ??
Offline DavidAlfa
Re: Unknown IC
« Reply #11 on: November 28, 2024, 09:20:08 pm »
What about the FNB35060T6S?
Onsemi site says it's "Double stopper", no idea what it is, otherwise seems identical and readily available.
Offline Ugur
  • Country: tr
