Author Topic: unknown PWM controller  (Read 798 times)
Offline mooseTopic starter
« on: February 22, 2023, 04:25:37 am »
Hi
Does anyone know what 6pin PWM controller this is...its on a (non-working) Black&Decker 18V Li-ion charger.
thanks
Offline Kim Christensen
Re: unknown PWM controller
« Reply #1 on: February 22, 2023, 04:51:57 am »
It could be a R7731... Check the pinout and function from the datasheet against your circuit.
The following users thanked this post: moose
« Reply #2 on: February 22, 2023, 05:37:56 am »
sheesh Kim..it certainly seems to be it...THANK YOU!
As a matter of curiosity, is this a chip you've come across previously or are you familiar with the marking or...?
« Reply #3 on: February 22, 2023, 05:51:38 am »
I just went and checked a SMD code page that I've used in the past. Maybe I got lucky with that one.
« Reply #4 on: February 22, 2023, 06:43:06 am »
now thats a 'double' thank you...excellent SMD markings lookup site!
Offline fzabkar
« Reply #5 on: February 22, 2023, 08:55:53 am »
« Reply #6 on: February 22, 2023, 10:08:41 am »
also excellent!
thanks for that.
