Pfuuuuu, found it...
https://www.schott.com/epackaging/english/cutoff/sh_type/d6.htmlD6 Type
Series: D6T, D6X, D6WX
The D6-type uses a ceramic material for the body (cap and base) and
integrates a resistor as a heater inside the thermal cutoff. Hence, the D6-type
can be activated either when the abnormal temperature increase is caused by
the external environment, or when it is a result of the heat generated by the
electrical circuit within the device. This provides a second protection for the
electrical equipment in which the D6-type is installed.
The D6-type is available for 12A and 15A (DC).
