Author Topic: FLUKE 5500A REPAIR  (Read 4085 times)
Offline HUGOMANTopic starter
FLUKE 5500A REPAIR
« on: January 10, 2022, 10:47:46 pm »
Hi to everyone
This calibrator gives error 1503 when i generate 1V or 10 ohm then it gives a second message 399 who is A/D COMM is the issue.
welcome to your ideas and experiences big thanks to you
Regards
« Last Edit: January 12, 2022, 08:14:41 pm by HUGOMAN »
Online Kim Christensen
Re: UNKOWN RESISTOR HELP
« Reply #1 on: January 10, 2022, 10:53:13 pm »
It may not even be a resistor network...
If you post the make and model number of the unit that this PCB is from, it may get you better responses.
Offline abdulbadii
« Reply #2 on: January 10, 2022, 11:04:59 pm »
you, I, we read it Z
zener diodes net beside jack/jumper (JK)?
« Reply #3 on: January 10, 2022, 11:28:24 pm »
This one is in the board A6 of FLUKE 5500A, it is ceramic package and the reference printed there is 946087.
Thanks
« Reply #4 on: January 11, 2022, 12:07:12 am »
I found a schematic. Looks like it is a custom resistor network for Fluke.
Offline coromonadalix
« Reply #5 on: January 11, 2022, 12:20:21 am »
The obvious source would be Fluke   send them an email,   its a custom made
You wont get it, unless you buy an a6 board for parts and this network resistor is good,
seems to have been tampered,  huge solder amount on the pins ???
« Reply #6 on: January 11, 2022, 09:10:39 am »
Sure they can sell me the A6 board ? do you have an idea about price ? awsome
Offline max-bit
« Reply #7 on: January 11, 2022, 11:11:10 am »
The module is made to order - read unless you buy, for example, on ebay (used - functional) otherwise rather impossible to get
The following users thanked this post: HUGOMAN
« Reply #8 on: January 11, 2022, 03:34:24 pm »
Or  try to carefully desolder it, and try to measure all the resistors on the given schematic pinout ??  if one value is busted, maybe try a substitution in paralell ???
« Reply #9 on: January 11, 2022, 03:39:16 pm »
THANK YOU SIR
i think the samething but i am still guessing about power of resitor that i will put 1/4 watts for the tol i will put 1%?
Do You agreed with this plan? :scared:
All The Best
« Reply #10 on: January 11, 2022, 06:16:12 pm »
Well to do some test   it should do the job
But for precision wise,  it will not do if you intend to do scope calibration after the repairs
You need to know  when its possible  the resistors  caracteristics / precision / tempco  tolerance ....  to do a correct substitution
Offline alm
« Reply #11 on: January 11, 2022, 07:28:21 pm »
I don't know the function of the A6 board, but it may well be that they are using a hybrid for temperature coefficient matching and thermal matching of the different resistors, so their ratios stay context (like in a voltage divider). In that case, trying to supplement the original resistor with a series / parallel resistor (if the original drifted but is stable now) might be best. Otherwise, I expect that a low tempco precision wirewound for Vishay bulk metal foil to be a closer match than a 1% resistor. But of course for an initial test you can use something more basic. It would not surprise me if it fails self calibration / self test with a lower spec resistor.
It's a higher spec calibrator, but TiN writes about the Fluke 5700A that the resistors on the Ohms board have a temperature coefficient up to 1 ppm/°C. Your 1% resistors might be hundred times worse.
« Reply #12 on: January 11, 2022, 10:00:11 pm »
the problem is those kind of components could not be found everywhere, i will tell more details about this calibrator issue, i don't know if i continue here or i make a new post?
Thanks
Offline alm
« Reply #13 on: January 11, 2022, 10:07:25 pm »
I suggest creating a new post and linking to this thread in the first post. In that post, do an as good possible job of describing the state of the unit, history if known and current symptoms.
If you continue with this thread, at least change the title of the first post to something more meaningful like "Fluke 5500A repair" ;)
« Reply #14 on: January 12, 2022, 02:02:48 am »
Instead of strating a new thread
Simply change your first thread title  ''Re: UNKOWN RESISTOR HELP'' to a  FLUKE 5500A repair ?? I dont think the mods would be angry ?
Offline CaptDon
  • Country: is
« Reply #15 on: January 12, 2022, 03:49:41 am »
It is of course a laser trimmed ceramic resistor network. Done so they could be trimmed to better than 1% tolerance, sometimes to .1% tolerance. Love the Z=Zener network reply, hehehe, not hardly, if it were you would see the bulges and it would be overlaid in the typical green epoxy.
« Reply #16 on: January 12, 2022, 08:30:39 am »
YES OK
Offline CaptDon
  • Country: is
« Reply #17 on: January 12, 2022, 02:53:27 pm »
We often see 'Z' as representing the impedance of a 'network' and somehow these hybrid resistor 'networks' are indicated with a Z. As in Z1, Z2 etc. on the artwork and in the schematic. Many years ago they used to use customized modules with resistors, capacitors, diodes, transistors and even specialized I.C.'s to save space. They were ceramic hybrids often with printed laser trimmed resistors and generally coated with green epoxy and also often a brownish yellow encapsulation. In the television and radio circles they were often called 'Plates'. I have seen schematics marked as "HY' or 'HM' (Hybrid Module) and often seen them called 'I.C.' as in I.C. 10 etc. Among Zenith and many others they would not release any information on what was contained in the 'plate' and when these went bad and were no longer available that was an end-of-life for your device. So reverse engineering them became very common. Case in point, the 'greenie' used in Tektronix TDS420 power supplies. An 'unobtainium' part even since the day those scopes were released. They have been reverse engineered and can be duplicated today. Besides being space saving these little wonders often protected a product from being easily duplicated. Cheers!!
Re: FLUKE 5500A REPAIR
« Reply #18 on: January 12, 2022, 08:16:11 pm »
Hi to everyone
Regards
« Reply #19 on: January 13, 2022, 08:15:05 am »
Hi to everyone
Regards
« Reply #20 on: January 13, 2022, 07:29:45 pm »
If I was attempting to fix this, I would determine which resistor(s) in Z8 is open and temporarily bridge an equivalent one across. (Series/parallel/pot combo to get the right value)
Then see if the error messages go away. If not, then you have other things to fix as well.
« Reply #21 on: January 13, 2022, 08:22:42 pm »
Hi Mr KIM first thanks for your positif message  :clap: :)
i am going on and i am sure that i will arrive. i will let you know the final status.
1 thing  :-// to get your point of view:
does the digital curve tester help to find really the defective component or just commercial testers! i mean the manual method remains the best!
what do you think ? i ask everyone about this.
Best Regards and thanks for this forum's Dave :-+
« Reply #22 on: January 13, 2022, 09:54:46 pm »
Which digital curve tester are you using? Model number? Or picture of it.
« Reply #23 on: January 13, 2022, 09:59:26 pm »
no not yet i plan to buy it but i dont have it yet. so maybe it helps ?
Offline dcmxx
  • Country: mx
« Reply #24 on: May 17, 2022, 06:14:48 pm »
Hi. a little bit off topic. but I'm looking for a A9 Main CPU board for a 5500a calibrator. If someone has one to sell i might be interested in purchasing it
