As a kid back in the '60s, I pulled apart a lot of valve radios, but never really worked on them, or tried to repair them, until now.
I'm trying to restore an Astor Mickey (the HNQ "breadloaf" model with permeability tuning).
Model pics and overview:
https://www.radiomuseum.org/r/astor_mickey_hnq.htmlA very nice tech bulletin with schematic and parts list:
https://www.kevinchant.com/uploads/7/1/0/8/7108231/hnq.pdf
But I'm unsure about the status of the two front end valves.
I've re-capped the radio (2 electros & 10 paper), and replaced about 5 resistors that had drifted high.
I get high tension voltages, but they are low at 163v/135v, vs 195/175v on the schematic.
The two voltages are across R37, a 450R (460R measured) resistor. The low values and higher current (61mA vs 44mA) indicate a possible undue load on the supply. But the voltages are enough to get some scratches, clicks, hum and tones out of the speaker.
(more static right at one end of the tuning, but no radio sounds)
Clearly, the 6X4 rectifier and 6AQ5 audio amp are working, but I'm sus of the 6BE6 front end and 6AD8 IF amp.
The 6X4 and 6AQ5 are too hot to touch after a few minutes operation, but the 6BE6 is only slightly warm, and the 6AD8 not at all.
The filaments appear to be glowing, but not brightly. I bought a "new" 6AD8, which makes no difference (haven't found a source for a new 6BE6 yet)
Filament voltage is good at the sockets (a dial illumination bulb connected to the socket pins lights up brightly)
As best as I can tell, the filaments of these two tubes measure about 3 to 3.5 ohms, and the two good ones 2 to 2.7 ohms (at cold).
The unit draws about 38W from the mains, which agrees with the spec of 40W.
My questions are:-
Shouldn't the 6BE6 and 6AD8 be too hot to touch after a few minutes?
(that's how I remember it with valve gear)
Do valve filaments die by just going colder as they wear out?
Are the higher cold filament resistances of the the two cool tubes significant?
Could my "new" 6AD8 be a dud?
Can anyone in Melbourne assist me with tubes to try/swap/sell, or with another HNQ for comparison?
Any help would be most appreciated.
