Author Topic: Unusual uneven brush wear in blender motor (Optimum 9400)  (Read 1857 times)
Offline fzabkarTopic starter
« on: January 01, 2019, 07:29:42 am »
Some time ago a friend asked me to help him troubleshoot a commercial grade blender, model Optimum 9400. The symptom was that the blender's motor either wouldn't start, or it would start intermittently. It turned out that the armature circuit was open. The stator was OK.
When my friend removed the brush holders, he found this:
https://web.archive.org/web/20230522151510/www.users.on.net/~fzabkar/Blender/worn_brush.jpg
The short brush wasn't stuck -- it really had worn down that low. We couldn't find any reason for the dissimilar wear. All we were able to determine from the owner was that the unit had previously been returned to the supplier for service after it had failed a routine insulation test (why?). New brushes restored the unit to fully working condition, with no hint of arcing or vibration.
BOM for semis:
PIC16F1503, Microchip, 8-bit uC, 14-pin, 2.3V - 5.5V, 16MHz:
http://ww1.microchip.com/downloads/en/DeviceDoc/41607A.pdf
26T12BI, NELL Semiconductor, 25A, 1200V TRIAC, TO-3P:
http://nellsemi.com/nell-cht/certi/9c3e7f1f6191ff20c800af7842994fff.pdf
MOC3023, Fairchild, optocoupler, 400V Phototriac Driver Output:
http://www.ti.com/lit/ds/symlink/moc3022.pdf
PT-1540P, Mallory Sonalert Products Inc, buzzer, 4kHz, 5Vpp, 1.5mA:
https://www.state-elec.com/store/PDF/PT-1540P.pdf
HT7044A-1, Holtek, TinyPower Voltage Detector, 4.4V:
http://www.sycelectronica.com.ar/semiconductores/HT7044A.pdf
Internal photos:
"a comparison of the parts that make up the blender":
https://www.froothie.com.au/Documents/Optimumv.sLowerQualityBlenders_20may2014.pdf
https://www.froothie.com.au/optimum-vs-lower-quality-blenders
User Manual:
http://www.froothie.si/Documents/Optimum%209400%20User%20Manual%20RO.pdf
(Romanian)
https://www.medirando.com/images/medirando/media/Optimum_9400_UserManual.pdf
(German)
My CCD scans of the control PCB:
https://web.archive.org/web/20230522151507/http://www.users.on.net/~fzabkar/Blender/Blender_PCB_bot_resize.JPG
https://web.archive.org/web/20230522151504/http://www.users.on.net/~fzabkar/Blender/Blender_PCB_top3_resize.JPG
https://web.archive.org/web/20230522151511/http://www.users.on.net/~fzabkar/Blender/Blender_PCB_top2_resize.JPG
« Last Edit: March 28, 2024, 03:50:08 pm by fzabkar »
Offline Armadillo
Re: Unusual uneven brush wear in blender motor (Optimum 9400)
« Reply #1 on: January 01, 2019, 08:02:44 am »
High Load, High Current, Positive Brush has been shown to wear faster by embrittlement process of the graphite.
« Reply #2 on: January 01, 2019, 07:56:05 pm »
It's an AC commutator motor.
