Hello here,
I have a Roland E-70 which doesn't work anymore ....
So first, (thanks to frisc0), the service manual can be found here (
https://www.synthxl.com/roland-e-70/) )
When switched on, everything lit on. LCD is fine all buttons ok etc. etc. (I did the test from the Service manual and everything is ok except the MIDI test because i have no cable to loop back In / Out)
So, PSU is ok.
The amplifier is Ok: when I remove the output from the DAC and connect a microphone with an pre-amp, it works fine.
So, obviously, I suspected the DAC area (GSE board) and its uPD6376. As far as I could check, the uPD is operating with L-ch and R-ch input alternatively. At least, I could check with a scope on pin 13 that I get two set of data bits.
Pin 13 gets a clock, ok
But from here, I have now idea on what to check.
I was hoping to see "something changing" while hitting some keys, on pin 13, but ... nope. Nothing change.
So, either it's because it's not the uPD which is faulty (and then something before), either I did not understand (this is much more "probable" :-) something in this DAC
Any advice would be more than welcome.
Thanks a lot to the community
So
