Author Topic: UR44 Audio Interface No Power  (Read 614 times)
Offline young_silent_made_itTopic starter
« on: December 07, 2023, 10:48:58 pm »
I have a Steinberg UR44 audio interface that I had in storage for a few years, and now that I want to use it doesn't power on. I want to take this opportunity to learn electronics repair so I am trying to repair it for learning experience.
I am looking for guidance on how to proceed with troubleshooting the problem.
I have checked the original power supply with a multi meter and it works.
I visually inspected the PCB board and don't see any issues, except what looks like a possible broken fuse but not sure. I checked it for continuity it reads 97 ohms, but 3 components that light up for a split second when I press the power button on the audio interface when I inspect the PCB board with a thermal camera.
This pictures shows where the power jack is(blue circle), which is right next to the power button, and the barely visible green square shows the area where the 3 components are heating up/lighting up for a split second when inspected with the thermal camera.
I am new to electronics repair, how should I proceed from here in troubleshooting the problem?
Thanks for the help.
« Last Edit: December 07, 2023, 10:55:34 pm by young_silent_made_it »
Offline David_AVD
Re: UR44 Audio Interface No Power
« Reply #1 on: December 08, 2023, 10:01:25 am »
Maybe start by measuring all of the ceramic / MLCC SMD capacitors on the resistance range of your meter. See if there's any shorts (or reading of less than 100 Ohms) on any of them.
The following users thanked this post: young_silent_made_it
