Some of those wires are covered in an enamel coating, which insulates the wire. If they aren't soldered together properly, there will be no electrical connection.
I recommend for you to disconnect the wires, burn off the enamel coating (don't burn the copper), and try solder them together again. If you have a multimeter, you can check for continuity at by probing both ends of the wire to make sure your solder joint has created an electrical connection.
