Some wire is woven with plastic. That allows it to be much thinner and flexible, not to mention cheap.
Try exposing the wire as best you can, quickly heat up with an open flame, blow it out if it catches on fire. Apply flux and drag
the end through some molten solder on your iron. You should see a small 1mm section tinned. Cut up to that and away
you go.
