Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
This topic
This board
Entire forum
Google
Bing
Home
Help
Search
About us
Links
Login
Register
Electronics
Repair
Use a HV microwave capacitor for HV CRT of RCA vacuum tube scope ?
« previous
next »
Print
Search
Pages: [
1
Go Down
Author
Topic: Use a HV microwave capacitor for HV CRT of RCA vacuum tube scope ? (Read 959 times)
lordvader88
Frequent Contributor
Country:
on:
January 25, 2018, 08:36:51 pm »
I have an RCA-WO33A vacuum tube oscilloscope. Its was dropped hard and the transformer broke loose, cracking the PCB in half and bending the frame/etc. Probably broke 2 tubes as well. The replacement tubes and caps got here today. But I don't have a 0.5uF >700V capacitor. But I do have 2 or 3 big microwave oven caps. I have to dig them up. But if they are rated about 0.5uF is there any reason they might not work well at 60hz from a rectifying valve/tube ? Its for the CRT
http://rhetoricity.com/misc/tubes/oscope/RCA-Oscilliscope-WO33A.pdf
Its C40 on the mid-right
Last Edit: January 25, 2018, 08:53:22 pm by lordvader88
Logged
Yansi
Super Contributor
Country:
STM32, STM8, AVR, 8051
Re: Use a HV microwave capacitor for HV CRT of RCA vacuum tube scope ?
Reply #1 on:
January 25, 2018, 08:41:24 pm »
They will work absolutely fine with 700V.
Just note there is usually a discharge resistor built in the cap, so you may see a false leakage current. It may or may not be a problem, depending on the circuit where you will use it.
Logged
james_s
Super Contributor
Country:
Reply #2 on:
January 25, 2018, 10:14:15 pm »
Remember that a microwave capacitor is used with 60Hz powering a vacuum tube in its native application.
Logged
Print
Search
Pages: [
1
Go Up
« previous
next »
Electronics
Repair
Thanking...
EEVblog Main Site
EEVblog on Youtube
EEVblog on Twitter
EEVblog on Facebook
EEVblog on Odysee
