Author Topic: Use an simplex impulse clock as a regular wall clock  (Read 170 times)
Offline electrofixTopic starter
« on: December 20, 2024, 10:21:16 pm »
I have a simplex 6310-9075 that I want to use as a normal clock.  Currently it is an impulse clock that can receive signals for correction from an impulse system.  I do not have the impulse system.  All I have is a 24vdc transformer which is the voltage it requires.  How would I connect it to bypass the "impulse" system and use it as a regular wall clock? Here are some pictures:
