Author Topic: UT 161 B selector  (Read 312 times)
Offline mzdenkovTopic starter
  • Country: hr
UT 161 B selector
« on: June 05, 2024, 08:03:53 am »
Hello
I've dissembled my UT multimeter and i saw a half broken "leaf spring contact"(or how are they called) on its selector .
Is this normal or?  Because when i look at it, this is a defect, but i stand to be proved wrong.
Ive contacted the store where i bought it, but they say this is ok.
Best Regards
« Last Edit: June 05, 2024, 08:06:36 am by mzdenkov »
To Solder or not to solder, that is the question!
Offline BILLPOD
Re: UT 161 B selector
« Reply #1 on: June 05, 2024, 06:11:03 pm »
Good Morning Mzdenkov,   If you can return it, do so;  don't believe the store telling you it is 'OK', it's not.   It might work for a while, but it flexes as you turn the selector knob, and will eventually break at the end opposite the current break, (I believe).
Online coromonadalix
« Reply #2 on: June 05, 2024, 06:16:11 pm »
for sure IT IS not okay  return this
  • Country: hr
« Reply #3 on: June 05, 2024, 06:55:44 pm »
I had a conversation with the service people.
They told me that they've dissembled another NEW unit and compared it to mine, and they saw the same symptoms...
So their conclusion was: "this is how manufacturer wanted it to be for better springiness of the contact" - rough translation.
+ if i disassemble it again ill lose my warranty.
Its like fighting with a wall when you talk to this people, so ill try to solder it together because i know it will break after 1year of use
which is outside of warranty period.
Basically 70€ trowed in the drain.
Thanks for your answers.
