Author Topic: UT136 multimeter  (Read 3012 times)
Offline gurujiTopic starter
UT136 multimeter
« on: October 27, 2014, 08:21:46 pm »
Hi Guys I have a UT136 multimeter and when I tried it's frequency option showed no readings. :(
Is there a way to fix this? Can I hook up this frequency meter to the 240v ac mains to check frequency and check if this meter works?
Thanks
Offline Shock
Re: UT136 multimeter
« Reply #1 on: October 28, 2014, 06:22:30 am »
If you don't have a signal generator, you can generate a 1KHz tone on a PC (google it) and measure it at the back of a speaker. The signal needs to be greater than 600mV rms and lower than 10V rms.
Make sure you have leads in the correct hole and are on the correct setting.
« Last Edit: October 28, 2014, 06:52:59 am by Shock »
Offline retiredcaps
« Reply #2 on: October 28, 2014, 06:32:34 am »
UT136 manual says
Never input higher than 10V rms for test frequency and duty cycle.
« Reply #3 on: October 28, 2014, 06:44:53 pm »
Hi guys thanks for response. Today I downloaded a freq generator on my android but still nothing on my meter.
I think it has a fault. Is there a technician here? maybe I try to fix the circuit board  :-\
Thanks
Offline Shock
« Reply #4 on: October 29, 2014, 03:12:56 am »
Did you measure the signal voltage on the AC setting?
« Reply #5 on: October 29, 2014, 09:02:35 pm »
Hi Shock yes the signal on AC setting is working ok.
