Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
This topic
This board
Entire forum
Google
Bing
Home
Help
Search
About us
Links
Login
Register
Electronics
Repair
Vacuum cleaner makes helicopter sound when working
« previous
next »
Print
Search
Pages: [
1
Go Down
Author
Topic: Vacuum cleaner makes helicopter sound when working (Read 554 times)
david smth
Contributor
Country:
on:
December 31, 2024, 04:39:41 pm »
The vacuum cleaner makes a noise when you touch the back of the machine or it makes a noise and then disappears but it sounds like a blockage sound but then disappears and makes a noise like a blockage sound while vacuuming. I changed the filters and hose but it didn't fix it. Everything seems normal. It vacuums the floor but it works and sometimes makes a noise like a blockage sound. Could there be a problem with the engine? What would happen if the engine malfunctioned? Would it not work at all or would it make a blockage sound? It doesn't make a normal vacuum cleaner sound, it makes a helicopter sound
Logged
david smth
Contributor
Country:
Re: Vacuum cleaner makes helicopter sound when working
Reply #1 on:
December 31, 2024, 04:50:18 pm »
The vacuum cleaner makes a helicopter sound when it is working. When I first turn it on, I turn it off and on again, then it is fixed. Sometimes it makes a sound by itself. I haven't found a solution yet.
Logged
david smth
Contributor
Country:
Reply #2 on:
December 31, 2024, 04:55:29 pm »
I will put a video for you to help me and the picture brand is not a very well-known brand, it is a subsidiary product of Chinese origin, there is a filter inside, there is only no bag
Logged
themadhippy
Super Contributor
Country:
Reply #3 on:
December 31, 2024, 06:21:10 pm »
fan blades on the motor rubbing? unless its made by harbin then its normal
Logged
david smth
Contributor
Country:
Reply #4 on:
December 31, 2024, 06:39:07 pm »
yes There are gears inside the engine that spin
and there is nothing inside, there is a burning smell, it makes a sound like a helicopter, then I turn it off and on, it fixes itself, sometimes it happens on its own
Last Edit: December 31, 2024, 07:21:19 pm by david smth
Logged
Xena E
Frequent Contributor
Country:
Reply #5 on:
December 31, 2024, 06:50:23 pm »
Motor bearing?
X
Logged
Zero999
Super Contributor
Country:
0999
Reply #6 on:
December 31, 2024, 07:22:24 pm »
Is the cleaning brush jammed causing the torque limiting clutch to slip?
Logged
david smth
Contributor
Country:
Reply #7 on:
December 31, 2024, 07:37:04 pm »
The filter you see in the picture is attached to the back of the vacuum cleaner and makes a different sound when I touch it.
Logged
max.wwwang
Country:
Reply #8 on:
January 01, 2025, 08:50:24 am »
First check if, when on, it sucks.
Logged
Neutral | grounded
BILLPOD
Country:
Reply #9 on:
January 01, 2025, 02:14:05 pm »
Maye the hose has developed a 'flap', which occasionally breaks loose and partially blocks the flow of air
Logged
david smth
Contributor
Country:
Reply #10 on:
January 04, 2025, 08:07:21 am »
Yes, it doesn't happen all the time, the problem happens sometimes, it works normally, the problem rarely happens.
Logged
Print
Search
Pages: [
1
Go Up
« previous
next »
Electronics
Repair
Thanking...
EEVblog Main Site
EEVblog on Youtube
EEVblog on Twitter
EEVblog on Facebook
EEVblog on Odysee
