Author Topic: Vacuum cleaner repair  (Read 2369 times)
Offline Its wednesday my dudesTopic starter
« on: March 12, 2021, 10:36:21 am »
Hi guys
Yesterday I discovered that my vacuum cleaner suddenly stopped working. But before throwing it out and replacing it with a new one I want to give it a repair attempt. Since I am dealing with mains voltage here and my usual projects is simple low voltage hobbyist stuff I wanted to get some input first.
Basically the vacuum cleaner gives no sign of life when turning it on. Cables are good. I opened it up and this is the board. So far I googled, that it consists a triac (package code something like BTB12 6008 DT (?), couldn't find the exact match). The other IC (package code CR8F6 1D12 (???), didn't find anything about it) might be a microcontroller. The board has a NTC thermistor connected to it. So would your plan of attack be? I was thinking about unsoldering the triac and testing it if it works according to this manual. https://instrumentationtools.com/test-triac-multimeter/
I was also thinking about a quick and dirty fix by bridging the triac contacts so that the motor just runs on full power all the time. Not sure if this is a good idea though, since there is a NTC present.
I've attached some pictures of the board.
Thanks!
Offline perieanuo
Re: Vacuum cleaner repair
« Reply #1 on: March 12, 2021, 11:09:23 am »
verify voltage on big electrolytic cap, with care, you have 220V on that pcb, maybe the blue thing is the fuse is it ok?
maybe you got lucky and some condensator is dead, like the yellow one who i guess make the small voltage for the IC with the rectifier diode next to him (D1?)
verify the zener also, maybe it's dead
the board should be easy to fix unless the IC is dead
The following users thanked this post: Its wednesday my dudes
Offline amyk
« Reply #2 on: March 12, 2021, 02:36:35 pm »
How "smart" is this vacuum to need a microcontroller...? :o
You can test the motor by bypassing the triac. I assume this is not a cordless one and the motor is a universal brushed motor.
The MCU looks like it's powered by a capacitive dropper so check the capacitance of C1 - they tend to fail by decreasing in capacitance over time.
If you don't need the "smart" extra features you can always get a suitably rated switch and turn it into a regular dumb vacuum.
Online wraper
  • Country: lv
« Reply #3 on: March 12, 2021, 02:39:10 pm »
First check if motor has continuity to begin with. It may be just worn off brushes.
Offline EHT
« Reply #4 on: March 12, 2021, 10:15:22 pm »
It looks similar to this Miele I fixed.
Oh yes! I was surprised by this too - same in the Miele!
Yes, that is what failed in mine. Measure DCV and ACV on the microcontroller's power lines. The thing which was most fiddle was finding a replacement that would physically match.
Also you can test the triac by using a bench PSU to apply a few volts to the gate and a small load like an LED. Test it in both directions. This was easy on the Miele because the triac was mounted externally.
« Last Edit: March 12, 2021, 10:17:32 pm by EHT »
Online wraper
  • Country: lv
« Reply #5 on: March 12, 2021, 11:06:55 pm »
I doubt that this is microcontroller. More like analog phase shift control IC for power regulation and overheat protection.
The following users thanked this post: 4cx10000, Its wednesday my dudes
Offline amyk
« Reply #6 on: March 13, 2021, 12:42:16 am »
I suspect it is one of the "CR8F" family, possibly CR8F6122: https://datasheetspdf.com/pdf-file/1054727/STMicroelectronics/CR8F6122/1
...of which there is disturbingly little information out there, just these datasheets, and zero mention of that product or even the "CR8F core" on ST's own website. :wtf:
Online wraper
  • Country: lv
« Reply #7 on: March 13, 2021, 01:50:48 am »
Pinout seems to match.
« Reply #8 on: March 14, 2021, 09:33:04 am »
Hi guys,
Thanks for your help. I worked through the list of your suggestions and turns out that the big capacitor was dead. Swapped out the capacitor, now the cleaner works flawlessly again. Thanks alot!
The following users thanked this post: najrao
Offline Raj54
  • Country: in
« Reply #9 on: December 05, 2023, 07:08:42 am »
Please be careful when checking the voltage on the large electrolytic capacitor. The PCB may have 220V, so exercise caution. The blue component may be the fuse - please check if it's okay. It's possible that a capacitor, such as the yellow one that provides low voltage to the IC with the rectifier diode (D1), is dead. Please also check the zener - it may be dead as well. Fixing the board should be easy unless the IC is dead.
Offline cruff
« Reply #10 on: December 07, 2023, 01:59:20 pm »
The original poster reported that it was repaired more than two years ago.
The following users thanked this post: amyk
