Author Topic: vaio mainboard layout (bios IC identifying)  (Read 5380 times)
Offline firstcolleTopic starter
« on: April 15, 2016, 09:55:50 pm »
Hi all,
this is my first post here on the forum but i follow the blog from about 1 year now..
i'm in trouble with a sony vaio vpcsb... i bricked the bios, so i'm trying to find out the flash chip and replace with a new one correctly pre programmed.
i opened the laptop and found the mother board model: MBX-237 rev. 1.3, i've found the schematics and identified the flash on the schematics, but..... how can i find this component on the PCB?? i didn't found any layout or image that can point me the right IC...
by looking at the board i think i've found it but i'm not 100% shure.
in attachment the bios schematic and a shot with the 2 flash, i suppose the bios is the 25L32
many many thanks
« Last Edit: April 15, 2016, 09:59:09 pm by ivo.colle@gmail.com »
Offline elecman14
Re: vaio mainboard layout (bios IC identifying)
« Reply #1 on: April 16, 2016, 12:15:11 am »
It more than likely is the 25L32. The 25L32 and the 25L512 both use 24 bit adresses for reads so it appears it would be possible to drop one in for the other. The larger chip would be more expensive though so barring a major part shortage it is probably unlikely a larger part was used if your schematic is accurate.
 Looks like the manufacturer opted to leave off the solder mask with reference designators. If you are able you should look for a reference designator or ref-des map (It should look something like this:) http://www.musicfromouterspace.com/analogsynth_new/SOUNDLABMINIMARKII/images/pcb_designators_large.gif
Offline amyk
« Reply #2 on: April 16, 2016, 01:43:35 am »
Look at the schematic, you'll find a 25L512 too and it happens to hold the firmware for the USB controller (observe that it's closer to the USB ports.)
Offline Rasz
    • My random blog.
« Reply #3 on: April 16, 2016, 01:46:29 am »
25L512 is usb 3.0 firmware?
edit: damn, amyk beat me to it
bios chips is so big because of all the UEFI bullshit (storage for variables)
« Reply #4 on: April 16, 2016, 06:26:04 am »
yes, i also thought that the 25L512 is usb 3.0 firmware (is located near the USB ports).
so 25L32 is for BIOS..
many thanks, and finger crossed!!!
Offline RGB255_0_0
« Reply #5 on: April 16, 2016, 12:09:19 pm »
Have you checked if there is a keyboard bind to recover the BIOS from USB? Usually Win+B and the BIOS may need to be renamed.
Your toaster just set fire to an African child over TCP.
Offline RGB255_0_0
« Reply #6 on: April 16, 2016, 02:04:00 pm »
I recovered an Acer I had using http://forums.mydigitallife.info/threads/13095-Undocumented-INSYDE-BIOS-recovery-method-Use-andy-s-tool-to-obtain-possible-names
Worth spending 10 minutes just trying that method at least.
« Reply #7 on: April 16, 2016, 02:16:31 pm »
I've tried this method but nothings happens.. I've tried some key combinations (win+b, FN +b, esc alt .....) and various name for the .rom files... The truth is that there is not a vaio procedure that explain exactly which keys to use and how rename the rom file..
Offline RGB255_0_0
« Reply #8 on: April 16, 2016, 02:27:57 pm »
Have you opened the ROM up in Andy's tool to see if it specifies a name of the file as they often need to be renamed. If still not working then it's toast :/
BTW, what did you do to brick it? Update the ME Region?
« Reply #9 on: April 16, 2016, 02:50:10 pm »
yes.. i've opened the rom files with andy's tool but the only popup that comes up is the one attached.. no name for the rom file...
i've installed a modded bios and disabled the intel graphic card.. my vaio has 2 graphic cards: intel and AMD and i wanted to force the amd to work......
« Reply #10 on: April 27, 2016, 10:07:14 am »
DONE!!
i changed the 25L32 with a one properly programmed!! all works fine!!
many thanks!
Offline RGB255_0_0
« Reply #11 on: April 27, 2016, 10:25:18 am »
Good stuff :-+
