Not sure what you are after (do you need help troubleshooting it?), but:
a) Don't buy mosfets from Banggood, AliExpress, eBay and similar sources - most are counterfeit and who knows what you have got. A lot of people received parts that blew up at 50% of the rated voltage/current or less.
b) If the original mosfets blew, then there is likely a reason for that. If you haven't found (and fixed) it, then simply putting new transistors in will make it go kaboom again. Setting your wallet on fire is likely simpler method of achieving the same result
c) Fan leads being shorted means two things - the fan wasn't spinning, so the PSU was likely running hot, the manufacturing quality of that supply is likely fairly suspect.
