I don't believe that there is any "standard" for this. It is what the manufacturer tells you it is, and you deal with it as you please. IQ baseband output with 160 MHz clock is pretty impressive. I usually deal with HP/Agilent/Keysight units with max clocks of <= 100 MHz which output their baseband IQ using single ended connectors (like BNC). Whatever the case, you have to interface whatever they give you to what you want. If you want single ended, and they give you differential, then you have to use a differential to single ended converter which will usually be an op-amp circuit. When I've done this in the past it has been some RFIC that has differential I/Q outputs that I wanted to convert to single ended, and I dead bugged an op-amp circuit on a piece of scrap PCB to do the job.
