Yeah, I had an SLP-R 1000 which I attempted to repair, and I'm usually able to fix stuff for which the parts can be obtained. I thought it must be possible, but I concurred with SoundTech-LG after wasting a lot of time. I got it working, but it was noisy/distorted at low volumes. One problem is that the components (especially the caps) are highly stressed by the combination of high-frequency, high-current and high-temperature, not to mention the vibration! It means that it sufffers from degradation of multiple components, most of which are a royal PITA to reach due to the stupid boxed-in design.
Also, the 370V is high current with all of those caps; it is *lethal* not just unpleasant.
So, easy change is wire the woofer directly to the rear terminals and use an external amp. Doesn't look as neat, but safe. BTW, I wired it up to a stereo linear amp which does 500W RMS in bridge mode. This can overdrive the woofer, so I don't know where they get "1000W" from. Still, at that level nothing stays put on your shelves!
