Author Topic: VHO Fluorescent Ballast: IceCap 660 Teardown / Repair  (Read 6398 times)
Offline theatrusTopic starter
« on: May 17, 2014, 01:03:28 am »
My venerable IceCap 660 VHO ballast (which I use with T5 lamps) on my aquarium started flickering and would not restart. After smelling the sickly smell of pop electrolytics, I decided to test the "Repairable" moniker.
First step not pictured: drilling out 4 rivets :(
Yup, thats popped. And sprayed everywhere.
The logic section. The connector on the bottom is for a dimming control signal.
IR2110 - driver IC
http://www.irf.com/product-info/datasheets/data/ir2110.pdf
TL594 PWM controller: http://www.ti.com/lit/ds/symlink/tl594.pdf
LM339 Comparator: http://www.ti.com/lit/ds/symlink/lm339.pdf
555 Timer  :-+ (time the ignition cycle?)
LM393 precision comparator
http://www.ti.com.cn/cn/lit/ds/symlink/lm393-n.pdf
The ballast transformers.
The input section (with the caps removed)
A current sense transformer (likely?) hiding under the big transformers. There is a row of passives under each of the two transformers.
IGBT: http://www.irf.com/product-info/datasheets/data/irg4pc40ud.pdf
I don't have caps which will fit in the height footprint of the case, but those are on order.
Software by day, hardware by night; blueAcro.com
Offline Evil Lurker
Re: VHO Fluorescent Ballast: IceCap 660 Teardown / Repair
« Reply #1 on: May 19, 2014, 03:09:04 am »
Wow that looks to be like a fairly high quality build. There are tantalum capacitors on the control side and even a silver mica capacitor in there!
If it were me I would consider doing a total recap job + replacing the MOV's. Might as well get all of them while you are in there.
« Reply #2 on: May 19, 2014, 04:12:28 am »
I figured it was of some interest as these types of ballasts are usually potted affairs - this is one of the few I've run into which was not.
Good catch on the silver mica - didn't even see it.
Offline amyk
« Reply #3 on: May 19, 2014, 12:04:14 pm »
That case style on D3/D4 is pretty rare too. I remember seeing those in military hardware.
« Reply #4 on: May 19, 2014, 02:41:48 pm »
MR756 Silicon 6A diodes: http://www.onsemi.com/PowerSolutions/product.do?id=MR756
ON has discontinued them, but they do appear to be available from other sources.
Offline thm_w
  • Non-expert
« Reply #5 on: May 21, 2014, 01:06:32 am »
Nice macro shots.
