For the record:
- the thing is a cheapo - but for the money if you ask - it is OK
- problem is: if you sum a cheap but solid design WITH LEAD FREE SOLDER...
- what do you get? a CRAPPY LEAD FREE SOLDER cheapo.
- several lead free solder joints were just CRAP. I mean CRAP.
After reflow some other joints and arranging the ROTARY SWITCH
which is not all that solid good...
The thing is working properly. Even that V1PH which BTW is indeed a 3.3V LDO
Summary:
- For 30/35 U$ an AC/DC CLAMP capable of 1000Amps is bargain
- Even if you have to reflow some crappy parts of the cheap crappy LEAD-FREE PCB
It is solid - it has no internal fuse (assumed that all job is in the clamp)
- protection is left to the MOV and PTC
with BONUS of a relative OK TrueRMS voltmeter and the usual DMM goodies
BARGAIN.
If you need a 1000A AC/DC clamp costing just U$30 box - it may be worthy
Paul
