Check again ... carving some tip if that BIOS is not from one of the
3 great ones.. AMI Award or Phoenix...
Usually ASUS, ECS, MSI, Gigabyte they don't write BIOS.
They use those 3 big players ready ones. Which btw are
always updated on a regular basis on their web... (the pcb fabs)
It helps just in case you want to follow the beeps.
Otherwise a POST card is far more reliable
as suggestions .. they are pretty much same
regarding good construction and no fab defects..
cheapos are always 50% chance.. but they do work just fine
