I have one experience in the late 80s, taking one of those apart. I repaired an open wire in the rotory transformer.
Unfortunately I put something back together with the wrong orientation so while it worked the pictured had some
sensor timing distortion. Actually took it with me to a Philips VCR training class and ask the instructor, he new just what to do.
Now, you seem to already have found the problem with just trying to spin the transformer winding. It needs to be connected to the head ass'y
which is connected to the bearing giving it support and centering it. So, ya you can't just spin that plastic piece with the winding without the head ass'y.
If that tape had video on it than there is clearly a head problem, could be dirty or broken. But, I'm not a 100% convinced the noise is from the video head bearings.
Can you isolate the noise with a tube, straw or stethoscope? Could it be a the capstan motor or one of those automatic head cleaner things that is not moving away
when it is supposed to? Or, less likely, something in the reel drive ass'y?
Is there any way to get the head motor ass'y to run outside of the unit, to either verify it as the source of the noise or rule it out?
Good Luck, Mikek
How did you go about repairing the wire in the transformer?
I don't remember the exact procedure, but I ended up with the unit, sometimes I bought them if the declined repair,
sometimes they just never picked them up.
But anyway the transformer was open, a visual inspection showed a clear brake of the wire inside in the actual track in the ferrite.
I somehow got the wire varnish cleaned off enough to get it soldered, and covered it with a thin coat of epoxy. That solved the problem,
and got video back, but I had something assembled wrong so the phase was incorrect and the picture was weird, I can't remember exactly, but the
sync signals were in the middle of the picture or some improper thing. Like I said I told the factory rep what I had done and he looked at the
picture and knew exactly what was wrong.
I can confirm that the noise is definitely coming from the head drum. Its not as obvious on the video, but it is obvious in real life.
I'm pleased to report some success
. I was sometimes getting a bit of resistance in the head bearing while spinning it manually, so today I put a little dab of oil in the bearing, and that has smoothed it nicely. I reinstalled the head and reassembled the camcorder and I'm pleased to say it more-or-less works and is very quiet.
Unfortunately I managed to break off one of the head chips from the drum, and it clearly needs some alignment. I am also getting a periodic, quiet, high pitched sound which I think is coming from the head.
Nonetheless, it works a damn sight better than it did when I got it
Maybe now that it has some oil, running it a bit will help make it better.
If you broke the head, I think you will just need to replace the whole head ass'y.
I remember breaking one on a Hitachi, luckily a little paperwork finagling and the factory paid for it under warranty.
The statute of limitations has long passed!
Mikek
