Hello all,
I've been restoring two 1970 Onkyo Dynamic Four Amp/Receiver. One of them it has a few issues with the FM tunner that often fails to stay tunned (AM ok), but after replacing all Electrolitic caps on the Tunner, pre-amp board and main amplifier board, i've noticed that on both channels i get +- 15Vdc reading on the multimeter.
I've isolated the main amp board from the others, changed the transistors except the power ones's, checked all resistors, diodes, caps, tracks but still i get +/-15Vdc offset.
The other Onkyo hasn't been touched yeat, but i also get +/-18Vdc off set at speaker output's.
Test was done without a load, Aux input selected, Volume at a minimum, Balanced and Bass/Treble also at mid.
My question maybe foolish but here it is:
Is there any specific situation in old Audio amplifiers where this DC offset voltage is normal?
Thanks in advance.
