especially troubleshooting RCD/GFCI trip issues without the hassle of squeezing in a usual size ma clamp inside tight rats nests
I was going to get one of these smallish UT210E meters (against my better judgement) but now it seems I either have to look elsewhere and spend a LOT more ( = NO! )
or give it a miss and get along roughing it as I have,
Mine has been accurate and works great on DC or AC current which is all it gets used for in my tool bag. Small Jaw and form factor makes it possible to go places other meters simply can't (inside coffee machines in my case with the panels on). If it saves you 5-10 minutes on site a job by not having to remove extra wires and panels and you do 5 or 6 jobs with it throw it in the bin and buy another it owes you nothing at that time unless you work for free. At least that is how I am viewing this meter in my case. The NCV is a good feature too.
Different if your tools are a hobby or home thing then you only have a frustrating paperweight left.
As to plugging it into mains I wont be
I hear that!
the sockets taped over and supplied cheapie? leads won't leave the wrapper and stored or recruited for use elsewhere
My app as above would be only for AC ma clamping in tight spaces
and the ocassional DC go/no go check in a circuit where I don't want to cut wires (or risk hurried meter setting blunders)
add the ocassional 'parasitic draw' hunt in family/friends vehicles that we all love to blow a casual Saturday/Sunday afternoon on
oh well, the beer and pizza is free at the end of it, and everyone happy
as long as the meter doesn't get dropped hard or driven over...
For my purposes two of these may be the way to go, and still be cheaper than a decent cheap clamp meter
that may not go down as low as this niche gadget UNI-T clamp.
I can deal with the DC "zero out/don't move the meter" thing, I do that anyway with other clamps to get a steady come reliable reading
They may even last a while if I'm lucky (yeah, right...
) best I can do is keep packed in a Pelican foam lined case
with batteries removed after each use,
and pray I didn't cop two units from a Friday production batch
anyways, hope OP gets his sorted asap
