-)/?action=dlattach;attach=1616839;image)
Hello people,
20 months ago I bought 20 old defective cheap CD players to get some hands on experience on this type of device.... I now know enough to know that's it's not worth repairing, at least not if one is trying to make a living from it...
Managed to fix and flip a third of them, another third was not economically repairable and were trashed/scrapped for part. Another third, I decided to keep for myself because they have old Philips swing arm CDM4-11 in them and I like those. Then there is this last one, object of this thread, that I kept because of it's exotic engineering. The pickup is moved using a linear motor rather than the usual worm screw.
"Of course" it does not work, like all the others before it.
Problem is that I am trying to make space in the lab... and if I can't fix it then I fear I will find it hard justifying to myself that I should keep it...
So either I can fix it, or I take the difficult but rational decision to scrap it.
Problem is that I am failing at fixing it, so before I resort to scrapping it, I want to give it one last chance and decided to bother yuo all about it here.... hoping maybe some vintage CD player guru might know these beasts and recognize a common fault. I don't intend to spend 200 hours on it. I spent a few hours on it already,doing the easy / reasonable stuff. I am only posting here in case it's a common problem the experts already know about and which could lead to a quick fix.
Anyway, so it's a Technics SL-PJ25 as the title says.
Linear motor as I said.. .though in this particular case I am not sure it's relevant here.
Symptoms : when you insert a disc, it fails to spin the disc, hence does not detects it / reads the TOC.
If I close the tray with no disc present, so I can see what the pickup is doing, I can see that the drive does the usual / expected dance :
- pickup is moved to the center of the disc
- laser is turned on (I can see that easily with the digital camera)
- laser is moved up and down twice, to try to focus.
- laser is turned off.
It's everything I would expect it to do... except that at the same time it's supposed to spin the disc of course, and it does not.
I attached the block diagram and schematic pertaining to the spindle motor.
-)/?action=dlattach;attach=1616875;image)
There is IC402, an op-amp, that drives a push-pull BJT pair, Q403 / Q404 that drive the motor.
Then there is a "digital transistor" (as its datasheet calls it...) Q351 that turns the 5V power on or off to the op-amp.
Control signals : I see two lines coming out of that big "Digital Signal Processing" chip, IC301.
Pin #64, "PC" operates the switching transistors that turns the 5V power to the op-amp. So it's a digital output only.
Pin #65, "EC" OTOH must be analog, it operates between 0 and 2.5V and drives the inputs of the op-amp.
What I did
1) Measured the 5V rail = Good.
2) Measured +8V and -8 rail : good. more like 9 or 10 volts but hey, the more the betterer...
3) Shorted collector and emitter of the upper transistor, Q403, so as to send 8V directly to the motor, to make sure the motor works. It does.
4) Noticed that when I do that, after a few seconds the transistor starts to emit smoke, no kidding ! I am shorting it, how could it possibly go up in smoke, there is no current flowing through it ?!
5) checked Q351 : it's not turned on, hence not supplying 5V to the op-amp.
6) However its base is at 5V so of course it's not conducting.
7) Now back to the start of the command chain : the two pins from the big IC, that make it all happen.
That's were the problem is apparently there is zero activity on these pins when I insert a disc.
Because the drive is otherwise doing what's it's supposed to be doing with the pick-up, we can be sure that the drive knows it is supposed to spin the disc / power the motor.. but it does not.
So:
1) These two pins are fried, the chip is kaput, dead end.
2) The chip requires some more input/signals from the outside world in order to spin the discs.... and maybe this is jot working because of some discrete external component, hence fixable.... but too complex to trouble-shoot. That's where the gurus here might help : does this problem ring a bell, something I could check ?
Not holding my breath really, but I can't possibly scrap this player without at least TRYING to get some help from the forum, you never know !
Thanks for reading...
