Author Topic: Vintage Conar 255 Oscilloscope repair  (Read 246 times)
Offline jk99345Topic starter
« on: August 24, 2024, 11:10:10 pm »
Hello,
I picked up this old scope for cheap at a hamfest recently, it seems to be mostly functional with a few issues. The trace seems to be slightly rotated (which I can probably adjust easily with the trace rotation), but the trace is also slightly jagged rather than a straight line. I also get huge spikes (as shown in the second image) when adjusting the volts/cm knob. I assume this could be due to the switch, so I will try to clean off the contacts and inspect the solder joints.
2349869-0
Thanks
Re: Vintage Conar 255 Oscilloscope repair
« Reply #1 on: August 24, 2024, 11:11:58 pm »
The manual for this oscilloscope can be found here:
https://bama.edebris.com/download/conar/255/255.pdf
