Author Topic: Vintage DECtalk voice synth repair  (Read 1581 times)
Offline artelseTopic starter
« on: November 15, 2016, 08:39:17 pm »
On the desk I am attempting to repair a DECtalk voice synth from about vintage 1990. It sports a 80C186XL10 and a 87C51 and various logic, an AD7541 ADC, etc. Several caps were leaking and replaced all with equivalents. Also a voltage inverter LT1054 died and replaced it. Still the device outputs nothing sensible through the serial port and no voice greeting. :-X
I do measure rather high peaks on the databus, up to 10Vpp.. due to ringing? I checked the 5V supply and it got some dirt on it, but can this cause the ringing on the databus pulses? Can these peaks damage anything? See the attached images: databus, Vcc and clock-out from the cpu which isn't that great either.
Any advice is greatly appreciated. :)
Offline Tomorokoshi
Re: Vintage DECtalk voice synth repair
« Reply #1 on: November 16, 2016, 05:37:55 am »
Where is the probe ground connected compared to the pin you are checking? How long is the grounding wire? There could be some ringing if the ground is too long.
« Reply #2 on: November 16, 2016, 07:46:22 pm »
Good question. First I had a longer ground wire for easy probing over the board. Then I shortened it to the regular ground wire of approc.10cm and connected it right to the chip-under-test. I saw some reduction of ringing, but not what I hoped to see.
Any other idea?
